simple expression not working
COW Forums : Autodesk Maya
jeremy gates
on Jan 17, 2012 at 8:12:01 pm
can someone please tell me why this simple code won't work in the script editor:
pCube1.rotateX = nurbsSphere1.rotateX;
I keep getting snytax error message.
Besides the obvious of the objects names, capitalization, semi colon ending, and making sure that the script editor is in Mel I don't see anything else.
Steve Sayer
Re: simple expression not working
on Jan 19, 2012 at 7:19:11 pm
In your Maya help files, look for the page titled "Differences between expression and MEL syntax." Find it in "User Guide > Scripting > MEL and Expressions > Syntax".
Basically you're trying to use an expression in your script editor, which doesn't work. You'll have to use getAttr and setAttr commands instead for a one-time implementation like this.
Hope that helps.
© 2018 All Rights Reserved
