subsurface scattering
COW Forums : Autodesk Maya
Sarah Byers
on Jan 17, 2012 at 2:59:13 pm
I'm trying to texture a parachute using subsurface scattering so that the open parachute picks up the light from the sky behind it. I'm using the misss_fast_simple_maya shader which works fine on a default sphere but when I apply it to my parachute I can't get any back scatter coming through. It must be a problem with the shape of the parachute, is there any way I can fix it?
Steve Sayer
Re: subsurface scattering
on Jan 19, 2012 at 7:02:31 pm
Are you sure this isn't overkill? Could you get the effect you're after with some simple Translucency settings?
I don't know much about SSS, sorry.
