Motion path and animation problem
COW Forums : Autodesk Maya
Aaron Debreczeni
on Jan 16, 2012 at 12:46:38 pm
I want to rotate an object around a globe, and in the same time rotate it around its own axis.
I used a motion path to rotate it around the globe, but when I set a keyframe for it's own axis rotation, the object stops to move along the motion path. How can I solve this?
Aaron Debreczeni
Steve Sayer
Re: Motion path and animation problem
on Jan 19, 2012 at 7:00:47 pm
You need an extra transform so you can separate the orbit around the globe from the rotation around the object's own axis.
You could group the object to itself, or create a locator and parent the object under it. Then attach the group (or locator) to the motion path. This will carry the object along while leaving its rotation channels free.
Hope that helps.
Aaron Debreczeni
on Jan 19, 2012 at 7:03:47 pm
Aaron Debreczeni
