Shave and a Haircut impossible to do mapping ITS A BUG????????????
COW Forums : Autodesk Maya
gerald ruppen
on Jan 7, 2012 at 7:54:16 pm
Hello guys
I have a problem (in shave and haircut) and I dont know if its a bug. The root and tip color boxes, where I can load in a file does not work well.
I have a poly spehre. I apply a checker or a map to this spere. Than I do shape--> create hair.
Now I go to the attribute Manager and look for tip and root. The hue vualues I push to zero. And under Tip and Root color, I can load in a file.
Now I drag the used file on the sphere in this boxes, and nothing happens. It only takes effect when I use the Icon beneath the empty boxes. But then It creates a new file wit the place 2d node.... Its not possible to use the used map again?????????????????????
Thanks AGR
