polygon merge problem
COW Forums : Autodesk Maya
gary schofield
on Jan 1, 2012 at 6:05:09 pm
Hi
Ive had this problem before but cant remember solution...
I have combined and merged a poly character head on a poly character body, the problem is that the merged line of mesh has not become smoothly connected leaving a sharp corner...all vertices have merged correctly and are equal,the normals seem fine etc..
any help greatly appreciated.
thanks
Jacqueline Johnsen
Re: polygon merge problem
on Jan 4, 2012 at 2:48:52 pm
Did you fergot to merge the two objects?
If not select the object and check your normals by going to:
Display -> Polygon -> Face Normals.
Now all your faces will have a line sticking out indicating the normals. So you can check if they are all sticking out the right side(which is outwards). If not, correct by selecting the faces you need to correct and going to: Normals -> Reverse
Hope this helps. ^^
gary schofield
on Jan 7, 2012 at 4:22:51 pm
Hi
I didnt check the normals before merge but as i say they are fine now, ive hidden the problem within clothes since - probably one of those hicups that never happens again - thanks for reply
Steve Sayer
on Jan 4, 2012 at 5:05:03 pm
Maybe select the row of edges and soften them?
-Steve
