How to call an object from a MEL file?
COW Forums : Autodesk Maya
Mostafa Talebi
on Dec 31, 2011 at 6:37:34 pm
Hello everybody,
I have made several objects, and I want to use them as a mel script sp thata whenever clicking on that script, the object gets created. How I can achieve this?
Steve Sayer
Re: How to call an object from a MEL file?
on Jan 4, 2012 at 5:03:32 pm
I'd export the models to disk and then have the script invoke the 'Import' command with appropriate settings.
-Steve
Mostafa Talebi
on Jan 4, 2012 at 6:33:35 pm
can you please tell me how? assume that my file is named
cube.ma and is saved in import folder of the project, then what the script would be?
Steve Sayer
on Jan 4, 2012 at 10:16:52 pm
Sorry, I should have said 'the file command' instead of 'the import command.' There is a flag to make it import. In your case it would just be:
file -import "import/cube.ma";You just have to make sure the path works correctly and that should work.
-Steve
