How and where to enter Fcheck options (on MAC) to prevent automatic rescaling of large images ???
COW Forums : Autodesk Maya
Christian de Vietri
on Nov 27, 2011 at 10:34:09 pm
Hi everyone
I'm having a major problem with Fcheck - every time I import a large image it resizes it automatically to a fraction of its size.
According to the Autodesk Maya Online Help there is a command that will "Display images in full resolution preventing automatic rescaling of large images." ...that command is -F
My question to you is how and where do I enter that command?
The basic thing I need to do is create a large scale depth map image...
please please help, I haven't been able to find any info on any other forums!
thanks for your time
Steve Sayer
Re: How and where to enter Fcheck options (on MAC) to prevent automatic rescaling of large images ???
on Nov 28, 2011 at 2:57:08 pm
You'll need to enter it in a console of some sort. I'm not a Mac guy, but if you look around for how to access a 'console' or a 'system prompt' or a 'command line' in your operating system, you'll probably find your answer quickly.
-Steve
Christian de Vietri
on Nov 28, 2011 at 7:42:01 pm
thanks for your reply Steve - As far as I understand I can enter command lines in to the Terminal, but that doesn't seem to do anything...
for example i enter "fcheck -F" and it says
-bash: fcheck: command not found
or I enter "fcheck -F myfile.ext" myfile being the file that is currently open in Fcheck and the terminal says again
Do you have any other suggestions?
Is anyone else having this problem?
Steve Sayer
on Dec 5, 2011 at 2:49:09 pm
Maybe it's a path issue. Instead of just 'fcheck' you might need to put in the whole path to where fcheck is located.
On a PC, this could be worked around by adding fcheck's path to the system search paths, so that the OS automatically looked for it in the appropriate folder. I have a vague recollection of someone setting up something similar in a Mac environment for me once, but I don't recall the details, sorry.
Good luck!
-Steve
