Syntax error of MEL
COW Forums : Autodesk Maya
sana son
Syntax error of MEL
on Oct 24, 2011 at 3:14:55 pm
I am new in this field......I am trying to create own renaming tool with this script which I found from video tuto.... somebody plz help me..to find the solution.. m getting error since 5 days.... code is given below which i m using and getting error:
//Renaming tools
//Create the window
string $RNM_Win = 'window -t "Rename it!"';
// Make the window a columnLayout and adjustables
columnLayout -adj 1;
// Query your sellection
string $sel[] = 'ls -sl';
// For loop - so we can access and apply the command to each sellected object individually
for ($each in $sel) {
// Name field - acqure the name sellected objects and allow to rename
nameField -o $each;
// Button on window for closing out our renaming tool
button -1 "close" -c "deletUI -window $RNM_Win";
// Show out renaming window
showWindow $RNM_Win;
// Error: string $RNM_Win = 'window -t "Rename it!"';
// Error: Syntax error //
// Error: string $sel[] = 'ls -sl';
Steve Sayer
Re: Syntax error of MEL
on Oct 25, 2011 at 1:54:01 pm
I see two problems here.
First, your code uses the wrong single-quote characters.
The "window" command and the "ls" command need to be surrounded by these quotes: ` `
You should not be using these ones: ' '.
The ones you want to use are entered using the button on the top left of your keyboard (next to the number one).
Once you fix that error you will probably get another one, because in the "button" command you have used a number one instead of a lower case letter l (just before the "close" arguments).
-Steve
sana son
on Oct 27, 2011 at 3:40:03 pm
Thanks a lot Steve......
Everything was right what u told... and now am facing small error:
error: Can not find procedure "deletUI"
NB: when click on close button of renaming window above error is coming what is that actually? please help me
sana son
on Oct 27, 2011 at 3:42:48 pm
Thanks Steve......
error: Can not find procedure "deleteUI"
Steve Sayer
on Oct 28, 2011 at 9:44:09 pm
Hmm, that shouldn't cause an error. 'deleteUI' is a built-in Maya command, so you shouldn't be getting that error... make sure you have spelled it correctly.
-Steve
karan kumar
on Mar 28, 2014 at 7:16:15 am
Hello sir
I Installed IGERSHADERS V-Ray Material Presets Pro 1.0.1 For Maya 2014 but it's not working the error is this type....
can anyone help me......
// Error: Line 1.16: Syntax error
