Maya Batch Render issue
COW Forums : Autodesk Maya
roy rabbid
on Oct 24, 2011 at 4:39:14 am
Hey guys!!!!
You are my last resource to find a fix for a problem im having since googled but can't find a solution for this.
Im trying to render a maya 2011 escene using batch render. The render starts just fine, but after three or sometimes four frames it exits with status 1. The same happens once i stsarts a new batch render.
This happens even rendering from command!!!!! so i have to baby-sitt the machine to start a new batch render.
Rendering with mental ray with global ilumination and mia materials.
here is an extract from the render log:
JOB 0.8 progr: 45.0% rendered on Rodrigo-i7.8
JOB 0.8 progr: 45.4% rendered on Rodrigo-i7.8
JOB 0.6 progr: 45.9% rendered on Rodrigo-i7.6
JOB 0.8 progr: 46.3% rendered on Rodrigo-i7.8
JOB 0.6 progr: 46.8% rendered on Rodrigo-i7.6
Result: D:/My Pictures/Documentos 3d/Animacion Navidad/2_Taller/scenes/EscenaTallerAnimacionContPass__3728.ma
Fatal Error. Attempting to save in C:/Users/*******/AppData/Local/Temp/Rodrigo.20111020.0639.ma
JOB 0.5 progr: 47.2% rendered on Rodrigo-i7.5
JOB 0.5 progr: 47.7% rendered on Rodrigo-i7.5
JOB 0.5 progr: 48.1% rendered on Rodrigo-i7.5
JOB 0.7 progr: 48.6% rendered on Rodrigo-i7.7
JOB 0.5 progr: 49.0% rendered on Rodrigo-i7.5
JOB 0.5 progr: 49.5% rendered on Rodrigo-i7.5
JOB 0.5 progr: 50.0% rendered on Rodrigo-i7.5
JOB 0.5 progr: 50.4% rendered on Rodrigo-i7.5
JOB 0.5 progr: 50.9% rendered on Rodrigo-i7.5
JOB 0.5 progr: 51.3% rendered on Rodrigo-i7.5
JOB 0.5 progr: 51.8% rendered on Rodrigo-i7.5
JOB 0.5 progr: 52.2% rendered on Rodrigo-i7.5
JOB 0.5 progr: 52.7% rendered on Rodrigo-i7.5
// Maya exited with status -1073741819
JOB 0.12 progr: 76.3% rendered on Rodrigo-i7.12
JOB 0.8 progr: 76.8% rendered on Rodrigo-i7.8
JOB 0.12 progr: 77.2% rendered on Rodrigo-i7.12
JOB 0.3 progr: 77.7% rendered on Rodrigo-i7.3
JOB 0.7 progr: 78.1% rendered on Rodrigo-i7.7
JOB 0.3 progr: 78.6% rendered on Rodrigo-i7.3
JOB 0.3 progr: 79.0% rendered on Rodrigo-i7.3
JOB 0.3 progr: 79.5% rendered on Rodrigo-i7.3
JOB 0.3 progr: 80.0% rendered on Rodrigo-i7.3
JOB 0.3 progr: 80.4% rendered on Rodrigo-i7.3
JOB 0.7 progr: 80.9% rendered on Rodrigo-i7.7
JOB 0.3 progr: 81.3% rendered on Rodrigo-i7.3
JOB 0.9 progr: 81.8% rendered on Rodrigo-i7.9
JOB 0.7 progr: 82.2% rendered on Rodrigo-i7.7
JOB 0.6 progr: 82.7% rendered on Rodrigo-i7.6
JOB 0.9 progr: 83.1% rendered on Rodrigo-i7.9
JOB 0.7 progr: 83.6% rendered on Rodrigo-i7.7
JOB 0.5 progr: 84.0% rendered on Rodrigo-i7.5
JOB 0.10 progr: 84.5% rendered on Rodrigo-i7.10
JOB 0.3 progr: 85.0% rendered on Rodrigo-i7.3
JOB 0.6 progr: 85.4% rendered on Rodrigo-i7.6
JOB 0.3 progr: 85.9% rendered on Rodrigo-i7.3
JOB 0.9 progr: 86.3% rendered on Rodrigo-i7.9
JOB 0.6 progr: 86.8% rendered on Rodrigo-i7.6
JOB 0.7 progr: 87.2% rendered on Rodrigo-i7.7
Fatal Error. Attempting to save in C:/Users/********/AppData/Local/Temp/*******.20111021.0414.ma
By the way the window's UAC is dissabled as well as the firewall and the anti virus.
System specs
intel i7 960
24 gigs ram
Nvidia quadro 3800
2 hdd 1 tera each.
Can anyone help me?
Thanks a lot in advance and hope to hear from you guys!!!
Jules Bodenstein
Re: Maya Batch Render issue
on Nov 18, 2011 at 11:45:43 am
Hi Roy,
It seems like it could be an issue with Hyperthreading
You might want to try disabling hyperthreading to see if that helps.
Jules Bodenstein
Render-It
mjb@render-it.co.uk
http://www.render-it.co.uk
roy rabbid
on Nov 18, 2011 at 7:30:29 pm
Thanks a lot jules for your answer i'll try that.
by the way the render i finally did it by deleting the render passes, once done that it stopped to exit and rendered normally!!!
