Copy out Y axis numbers from an object for every frame.
COW Forums : Autodesk Maya
Jorge Quintanilla
on Oct 24, 2011 at 1:52:04 am
Hi everyone, I was wondering if anyone knows an easier way to copy a polygons Y axis numbers for every frame for 252 frames. My MEL scripting skills are not good enough for writing such script. So I have been manually doing that, and it is very very labor exhausting and very easy to make mistakes.
I would really appreciate any help. This number crunching is killing me.
Thanks in advance
Steve Sayer
Re: Copy out Y axis numbers from an object for every frame.
on Oct 24, 2011 at 1:41:18 pm
This shouldn't be too tricky, but as you say, you would need some scripting skills.
Do you want the information stored as a variable, or printed out into the script editor, or stored as a file?
Here's a version that will store it as a variable for you. You can then print that variable to see the values in your script editor:
float $values[];
for ($i = 1; $i < 253; $i++)
$values[`size($values)`] = `getAttr -t $i object.ty`;
Of course, you'll have to replace 'object' with the name of your object.
-Steve
Jorge Quintanilla
on Oct 25, 2011 at 3:19:37 am
Thanks for the help. Much appreciated ^_^b
