Importing .mtl file
COW Forums : Autodesk Maya
Caroline Damian
Importing .mtl file
on Oct 22, 2011 at 7:22:11 pm
Hi guys,
I been having problem import .mtl file on to .obj, it said "unrecognized file type" . I heard its better to import it as a .fbx.
Can please you help me?
Ben van Hamelen
Re: Importing .mtl file
on Oct 23, 2011 at 11:52:17 am
As far as I know you don't have to import the .mtl file. The .obj should read it by default. It may happen that the .obj file is not linked to the .mtl properly. Try checking the file in Notepad to see if the path is correct.
I've noticed that textures don't hold too well in an .obj export/import. So I usually don't bother. FBX should give better results, but that's not of much use if you're trying to import an .obj, I suppose.
© 2018 All Rights Reserved
