Connecting Vertices
COW Forums : Autodesk Maya
Tom Hamilton
Connecting Vertices
on Oct 22, 2011 at 3:45:48 am
Is there a method to connect two vertices separated by space with an edge? I know that in Blender it is possible to select both vertices and press F to connect them with an edge. Does Maya have a similar function?
Ben van Hamelen
Re: Connecting Vertices
on Oct 22, 2011 at 11:40:58 am
I think you're looking for the Bridge function. Select two edges, use the Bridge function (I think it's under Edit Mesh, otherwise under Mesh).
http://www.fireinthesole.com/
Tom Hamilton
on Oct 24, 2011 at 2:42:51 am
Thank you, that did the trick.
