mia_physicalsky and Image Plane issue
COW Forums : Autodesk Maya
Damian Grady
on Oct 10, 2011 at 3:36:09 pm
I hope someone can help with this.
I have an image sequence attached to the image plane of my camera. I’ve also created a Physical Sky & Sun from the render settings but my image plane image now looks really dull and milky and not at all like the imported image sequence. If I remove the mia_exposure_simple node, the background/Image Plane looks as it should but everything else looks blown out so that’s clearly not an option.
Is there a way to stop mia_physicalsky affecting the image plane at all? Or is there another work flow I should be using? I need the image plane image sequence as reference so I can recreate the correct lighting warmth/conditions in Maya.
Hope that makes sense.
© 2018 All Rights Reserved
