Maya Fluid Container Losing contant with its emitter
COW Forums : Autodesk Maya
Mostafa Talebi
on Sep 29, 2011 at 3:49:47 pm
Hello
I have a fluid 3d container, and an object inside as emitter(emitting smoke) and another emitter for generating heat. When I increase the resolution to 256 the 3d container starts emitting(in the sorrect and fine way), but the whole emitter slightly begins to go far from the object(emitter01). I have Auto Resize enabled and its maximum resolution is higher than the box resolution!!
Mostafa Talebi
Re: Maya Fluid Container Losing contant with its emitter
on Sep 29, 2011 at 4:02:07 pm
I found out the problem. It was attached to a cache(it was a cached fluid container) and in still cached mode I applied some changes which resulted in illogical results.
