particle collision with object fails
COW Forums : Autodesk Maya
Mostafa Talebi
on Sep 26, 2011 at 5:33:21 pm
hello
I have made the Dynamic Relation between particle and ground using the menu Particle/Make Collide, but as you see in the picture below the steam/smoke does not obey the relation and passes through the ground. How might I solve this issue.
THANKS
Steve Sayer
Re: particle collision with object fails
on Sep 26, 2011 at 7:37:12 pm
Maya Classic Particles only register collisions at their center, so if they have a large radius they can project halfway through a surface while still colliding with it properly.
One solution is to create a copy of the surface and move it down, then have the particles collide with that instead.
-Steve
Mostafa Talebi
on Sep 26, 2011 at 7:45:48 pm
you mean in past in studios they used programming to come up with a satisfying result? such as Mr. Zargarpour in ILM.
