alpha matte?
COW Forums : Autodesk Maya
gin lee
alpha matte?
on Sep 26, 2011 at 11:59:29 am
the sphere come up form the ground
how to hide the sphere under the plane
http://i868.photobucket.com/albums/ab249/gin1211/blast.gif
camera will move...
Thanks!!
Steve Sayer
Re: alpha matte?
on Sep 26, 2011 at 7:30:38 pm
Put a cube around the sphere under the plane. Then assign 'Use Background Shader' to that cube. It will hide the part of the sphere inside it.
-Steve
gin lee
Re: alpha matte?
on Sep 27, 2011 at 7:30:20 am
It works!!! Tks
gin lee
Re: alpha matte?
on Sep 27, 2011 at 6:00:17 pm
does it have anyway to hide and keep alpha...
Steve Sayer
Re: alpha matte?
on Sep 27, 2011 at 7:26:23 pm
You mean you want the box to hide the sphere, but you still want the shape of the sphere to be visible in the alpha? No, I don't think there's a simple way to do that. Maybe what you should do is forget the box, and use a layered shader on the sphere, set up so that is uses a 'Use Background Shader' below the surface, and a regular shader above.
-Steve
