Camera batch render problem
COW Forums : Autodesk Maya
john titor
on Sep 17, 2011 at 9:59:38 pm
I have a camera which I have pointed at an object in my scene, when I render manually it looks as it should be, however when I batch render I get different viewpoint, much closer to the object, than what I have it set at. I have the correct camera set in the render globals, the problem affects only certain render layers eg, luminance, geom matte, shadows. I have another layer with the other passes.
john titor
Re: Camera batch render problem
on Sep 17, 2011 at 10:15:22 pm
never mind, identified the problem
