Need of A simple mel Script
COW Forums : Autodesk Maya
Mostafa Talebi
on Sep 14, 2011 at 11:13:51 am
Hello
Does anybody have a mel script for turning on/off visibility of selected objects?
Steve Sayer
Re: Need of A simple mel Script
on Sep 14, 2011 at 1:37:50 pm
What's wrong with Ctrl-h and Shift-h?
-Steve
Mostafa Talebi
on Sep 14, 2011 at 1:59:57 pm
that was a problem in my question.
I want to hide them only in render. I mean Render Primary Visiblity
Steve Sayer
on Sep 14, 2011 at 2:27:50 pm
Ah, okay, that does make more sense. :)
Before we get into writing a script, are you aware that you can use the Attribute Spreadsheet to change this attribute on multiple objects simultaneously? Just select all the objects you want to effect, choose Windows > General Editors > Attribute Spreadsheet. Then go to the 'Render' tab and you should see Primary Visibility in there. Click on the column header to select the entire column, and type a 0 for off and a 1 for on.
Could that be a workable solution for you?
-Steve
Mostafa Talebi
on Sep 14, 2011 at 2:37:04 pm
yes, thanks.
you know i knew that and looked for it and didn't find it. now using your help I got to it.
thank you
