Viewport 2.0
COW Forums : Autodesk Maya
Dustin Ward
Viewport 2.0
on Sep 7, 2011 at 6:32:58 pm
I'm new to maya.. with that said, why is it that whenever I switch to viewport 2.0 rendering my text just turns pink with no shading? I was expecting a high quality render.
Shahin Ghahremani
Re: Viewport 2.0
on Sep 8, 2011 at 7:13:48 pm
Which maya version are you using? viewport 2 become a realtime GPU renderer from maya 2012. which means you can see some of the effects in this mode realtime like Ambient Occlusion, Camera DOF, and some more, but only if your GPU supports OpenGL 3 and above. if it doesn't show your shader properly it might be because that shader you use has some links that is not possible for viewport 2 to render them or maybe a graphic card problem or something!
try update your gpu driver and directx first, maybe it works.
