Metal surface with geometry showing in render
COW Forums : Autodesk Maya
Amanda Tomas
on Aug 25, 2011 at 1:55:26 pm
I modeled text in Maya and when I render using any anisotropic surface, my geometry clearly shows. (I created this text because it was an already customly made text, otherwise I'd just use Maya's text function if this text was available to do so....)
What can I do to the geometry to clean this up? Adding divisions sure doesn't work.
