Transformation numbers problem
COW Forums : Autodesk Maya
Ray Foster
on Aug 13, 2011 at 1:24:05 am
I have an object that was imported from a 3D model seller. When I set its transform x,y,&z settings to zero the object responds to the changes but it doesn't move to the centre of the grid. There appears to be some kind of offset at work but I can't figure out how to find it. The manipulator appears to be centred in the default position.
Any suggestions?
Steve Sayer
Re: Transformation numbers problem
on Aug 15, 2011 at 2:22:47 pm
Can you just center the pivot (Modify > Center Pivot), then snap it to the origin, then freeze transforms?
-Steve
Ray Foster
on Aug 19, 2011 at 12:39:00 am
Thanks Steve, this has solved one problem and created another. Having succesfully positioned the pivot point I moved the object to grid zero by using the Snap to Grid function and now the x and z values are off by a small fraction. If I change them to zero then the object moves off centre.
Life wasn't meant to be easy.
Steve Sayer
on Aug 19, 2011 at 4:02:34 pm
I think you're forgetting to freeze transformations after snapping to the origin. Give that a shot.
-Steve
Ray Foster
on Aug 29, 2011 at 9:14:06 am
Yep, thats fixed it. Thanks
