Error: Socket error creating command port Comes and Goes
COW Forums : Autodesk Maya
Ray Bermudez
on Jul 30, 2011 at 4:15:59 am
Hello everyone,
Im using Maya 2012 and I have an issue where I received this error when trying to batch render my project...
// Error: Socket error creating command port
I made sure the firewall isnt blocking maya.exe
I also changed the file/project under prefrences to OS native
( a tip received from another forum)
...the percentage portion appeared frozen on the command line as if it was not rendering but to my surprise after I checked the maya/images folder, the renders were there.
I continued to render out some frames, when it was done I tried to render another set, and thats when it gave me that same socket error message again.
I could not figure out why, tried a few things but of course nothing worked so I shut down the computer but later when I started my computer up again and tried to render, it worked fine again.
Also, I did notice that the File/project preference was reset to
Maya Default.
Can someone please tell me why this error comes back and goes away again please? This is extremly frustrating.
Ray
