particles/materials changing colour as they pass a point in the scene
COW Forums : Autodesk Maya
Rupert Roderick
on Jul 26, 2011 at 11:03:21 am
Hiya,
I need to make particles 'pick up' a colour as they go through a curve flow.
I'm guessing there is a utility node that could do this somehow. Could anyone suggest one that might work?
thanks
Rupert
Steve Sayer
Re: particles/materials changing colour as they pass a point in the scene
on Jul 26, 2011 at 1:39:21 pm
I believe that a curve flow setup will cause all particles to pass a certain point along the curve at exactly the same age. Therefore, a simple colour ramp reading 'ageNormalized' and connected to rgbPP should do the trick.
Post again if you need more directions.
-Steve
Rupert Roderick
on Jul 26, 2011 at 1:56:34 pm
Genius! thanks steve
