A problem about Wrap deformer tool
COW Forums : Autodesk Maya
Kong Mao
on Jun 24, 2011 at 6:22:31 pm
Hi there,,for control poly hair by hairsystem,I use Wrap deformer to set curve driving the polygon hair,but there's some problem appears.that is when I rotate or move the curve(influence object),there are not rotate or move synchronization.
I use a curve and cylinder to explain this problem.
Frist I use Wrap deformer to let the curve control the cylinder.then I move the curve,the cylinder will move the double distance.
Is anyone know the solution for this?
Sorry for my bad English:)
Steve Sayer
Re: A problem about Wrap deformer tool
on Jun 27, 2011 at 2:45:03 pm
It looks like one of two things:
1) Maybe your original cylinder is parented under the curve? This would produce a double-transformation effect like you're experiencing. Make sure you're not moving the cylinder and the curve at the same time.
2) Maybe the wrap deformer doesn't work properly with a curve. Try using the Wire tool instead; that's the more common curve-based deformer.
© 2018 All Rights Reserved
