attaching Ncloth to other objects
COW Forums : Autodesk Maya
Felix Wright
on Jun 1, 2011 at 3:43:10 pm
Hi guys, im new to the forum and relatively new to Maya.
If it helps im using 2011 edition. Basically Im trying to replicate a spear, attached to the spear are wax seals with paper (thier named purity seals). I've followed a few tuts and managed to make a nurbs curve a cloth which seems simple enough. However, i would like it to obviously stay in one place, with the wax seal on top. I tried parenting the cloth to the cylinder which is a stand in for the seal, but that didnt work. Any ideas how to do this?
Much appreciated for any help give
Steve Sayer
Re: attaching Ncloth to other objects
on Jun 1, 2011 at 4:24:34 pm
I believe you will need to use an nCloth constraint for this. A Transform constraint would probably do the trick for you.
-Steve
