Wallthickness of object/tower
COW Forums : Autodesk Maya
Thomas Veiteberg Holan
on May 27, 2011 at 11:30:14 pm
Hi all!
I'm really new when it comes to using maya (architecturally) but I have made a pretty complex mesh with backturning double curvature etc, which is a design for a high desity housing tower.
Now, After smoothening the design etc I'm left with a "complex" shell, that needs a thickness to be structurally upholding..
Is there anyone who know the "comand" for this? I've been trying Mesh>Extrude, but as I1m really new to this program, I could need some help! =o)
Thanks in advance..!
Steve Sayer
Re: Wallthickness of object/tower
on Jun 1, 2011 at 4:29:26 pm
It sounds like you want to select your object and then use the 'extrude faces' command. This will produce a thick slab from a thin surface, though if your curvature is complex you may find you have to clean up some areas.
© 2018 All Rights Reserved
