3D paint in Maya 2011
COW Forums : Autodesk Maya
Tegan Radford
on May 27, 2011 at 2:42:49 pm
Hey guys!
So i am a complete noob and creating a biped model in MAya which needs to be coloured in. i have been trying to use the 3d paint function as i dont really understand how to make a uv work.
the problem im having with the paint is that when i paint on one section say green, it randomly puts green in another section of my model. so im doing just the arm at the moment which i created using extrude then moving vertices and that around to the correct positions.
as you can see (hopefully) i didnt paint "it outside the lines" on purpose when i filled in the other side it just randomly painted where i didnt want it too.
if anyone knows how i can solve this that would be really cool.
thanks in advance
Grant Gomm
Re: 3D paint in Maya 2011
on May 27, 2011 at 5:31:24 pm
Hi Tegan,
I'm not sure how to explain how to do that in just one post. It's kind of involved. But I highly recommend you check out digital tutors tutorial "Texture Painting with Maya and Photoshop". There are some concepts that I think are fundamental to texturing and painting that I know I could not figure out on my own. This tutorial will teach you how to use UVs and use the 3d paint function. I tried to learn that on my own and it was really frustrating. The tutorials really make a difference.
Best of Luck.
-Grant Gomm
http://www.blacklionproductions.com
Tegan Radford
on May 28, 2011 at 5:09:35 am
Hey Grant!
Thank you so much, I was freaking out as my assignment due date is fast looming!
I went to the digital tutors website and actually signed up for months account and found tutorials on uv mapping, 3D painting etc and using photoshop to paint instead, which is a lot more accurate! and definately would not have figured out on my own, so thanks again! :)
Tegan
Grant Gomm
on May 28, 2011 at 3:12:26 pm
Sure Tegan. I hope you find it as helpful as I did. Best of luck.
-Grant Gomm
