Rigid body does not work
COW Forums : Autodesk Maya
Zulaiha Rahim
on May 27, 2011 at 3:48:31 am
Hi I need help asap.
I have done a whole range of dynamics in maya but today as I assign a new rigid body to a new polygon that I have created. It opened a new tab called "pasted_RigidSolver".. Now my rigid body does not work. Everything went through it even when the normals are facing at the correct direction.
Steve Sayer
Re: Rigid body does not work
on Jun 1, 2011 at 4:49:03 pm
The 'pasted__' prefix appears when you use copy and paste (Ctrl-C, Ctrl-V) in your scene. I usually avoid this, because it rarely works out well.
Did you copy your rigid solver? You should create a new one properly instead. Or did you copy and paste your poly surface?
-Steve
