Can anyone explain this to me?
COW Forums : Autodesk Maya
Phil LeBeau
on May 23, 2011 at 5:06:15 am
I did a simple tutorial on how to do a texture just so I can get familiar with it and this is what happens when I render it
I know it is not a perfect match up but the render is not even close as you can see.
I am using Maya 7
Thanks for your help!
Steve Sayer
Re: Can anyone explain this to me?
on Jun 1, 2011 at 5:32:07 pm
My guess is that you have multiple UV sets on the object. For some reason one is showing up in your viewport, but the other gets used at render time.
Use the Relationship Editor to connect the texture to the appropriate UV set, or use the tools in the UV Texture Editor to delete the other set / copy the UVs over to it / whatever.
Not sure if that's the actual problem, but it's the first thing that comes to mind. Another possibility is that you've actually got two cubes there, overlapping one another...
© 2018 All Rights Reserved
