Rendering Issues
COW Forums : Autodesk Maya
Chris Shearin
Rendering Issues
on May 12, 2011 at 2:13:35 pm
Hey Cow,
So I need to render out some specific yet random frames from maya because they ended up getting corrupted. How would I go about doing this? Lets say I need to render frame 3, 10, 21, 23, 35, & 89? any thoughts?
Also I am using maya 2011
Thanks in advance.
PS im a new user to maya so the simpler the solution the better, IE. I would prefer not to use MEL if i dont have to
Stuart Christensen
Re: Rendering Issues
on May 13, 2011 at 5:18:20 pm
Hello Chris, just go back to your render settings window and render out each frame individually by changing the "from frame" box to 3, and the "start frame" box to 3, and end frame box to 3, Hit Batch render and it will render out that frame #3, and repeat process for the rest of the frames. Make sure they have the same prefix as the others because you will place them back into the image sequence. Hope that helps. Stu
© 2018 All Rights Reserved
