Adding new blend shapes to a rig
COW Forums : Autodesk Maya
Max Nuage
on Apr 28, 2011 at 2:05:40 pm
I'm currently working with a premade character model that is rigged and has some facial blend shapes as well. Since the facial blend shapes don't go much into detail I was doing a few additional ones for more detailed facial animation features which are required here. The problem is that I can't bind them in properly. :(
Most of the blend shapes I've created were made for animating the character's lips, the jaw however, is controlled via the skeleton.
The input list looks like this:
TSM2_skinCluster21 (I assume this is the skeleton)
blendshape2 (The already existing blendshapes)
I know that I have to assign my new blend shapes below the skeleton, otherwise the jaw bone won't affect it anymore. Now the main problem:
If I place my new blend shapes below the skeleton and define a number other than zero, the polygons go all over the place.
Is there any solution on this? :(
Thanks in advance,
- Max
Max Nuage
Re: Adding new blend shapes to a rig
on Apr 28, 2011 at 10:35:48 pm
Just figured out what's causing the issue... however, still no solution. I had to remove some polygon faces in the face partition to replace them with better ones. This always causes the blend shapes to screw up...
Could anyone thing of a method where I remove some of these polygon faces without screwing up the whole model? Unfortunately I only have a version of it that is already rigged...
Sarika Mirchandani
on May 2, 2011 at 10:28:29 am
Hi.
Could you mail me your file to know in detail where the problem lies!!
