Do indirect passes support transparent PNG?
COW Forums : Autodesk Maya
john slately
on Apr 27, 2011 at 4:27:19 am
I've noticed that when trying to get an indirect rendered pass (using IBL as lighting) the transparency information from a PNG texture isn't rendered out (number of channels set to 4).
Why is that? and how should I render out that information?
thank you for any help on this.
john slately
Re: Do indirect passes support transparent PNG?
on Apr 28, 2011 at 4:07:24 am
if it helps I also seem to get the warning
// Warning: (Mayatomr.Scene) : output data type "rgba_16" not directly supported by image format png, conversion performed by mental ray //
