can't modify shape sizes anymore
COW Forums : Autodesk Maya
Casey Kirchhoff
on Apr 22, 2011 at 6:41:20 pm
I used to be able to modify a cube's x y and z dimensions in the attribute editor under a tab which was third from the left.... it is no longer there for some reason. Can someone help me turn this tab back on? I am running Maya 8.0 Thanks!
Tibor Bernscherer
Re: can't modify shape sizes anymore
on Apr 24, 2011 at 9:54:58 pm
Did you try Display-UI Elements_restore UI Elements?
Casey Kirchhoff
on Apr 25, 2011 at 4:41:02 pm
That didn't do anything that I can see. Thanks for the reply
Steve Sayer
on May 2, 2011 at 6:06:21 pm
It sounds like you have deleted history on your object, which removed the 'make poly cube' node from your scene. If that's what happened, you can't get it back without creating a new cube.
-Steve
Casey Kirchhoff
on May 3, 2011 at 4:43:35 pm
Even when I create new shapes that node doesn't show up. It's like it just disappeared altogether! I am really at my wits end, and may end up having to re-install because I use that node all of the time. Thanks!
Steve Sayer
on May 4, 2011 at 1:32:04 am
Creating nodes with history is an option. Look for the 'History' button on your toolbar. It looks like a little scroll of paper, and right now it probably has an X through it. (Appearance may vary depending on your version of Maya.) Click on it to reactivate construction history and all newly-created primitives should have creation nodes attached from then on.
-Steve
Casey Kirchhoff
on May 4, 2011 at 11:42:49 pm
Steve you are the MAN! That's exactly what what I needed. Thanks so much!!
