Removing a Texture from a Lambert
COW Forums : Autodesk Maya
Dan Donaldson
on Apr 6, 2011 at 2:10:45 pm
Hello. I want to change a lambert the I assigned to an object from a texture to a plain color. How can I remove the texture from the lambert?
Stuart Christensen
Re: Removing a Texture from a Lambert
on Apr 6, 2011 at 7:19:34 pm
In the Hypershade just click on the texture node assigned to the lambert and hit Delete. Change up the color of your lambert as you see fit. Hope that helps.
