.Obj File Export with Render Quality?
COW Forums : Autodesk Maya
Natalie Loh
on Apr 2, 2011 at 5:02:18 am
Hi. Maya beginner here.
I recently leant how to do lighting using HDRI and I like the way my model looks when rendered.
Is it possible to achieve that look and quality when the model is exported as an .obj file?
I'm really sketchy on this, so please help!
I need my model to be in an .obj file format to import it into another software but when I did that, I was unhappy with how bad it looked. Is it impossible to export as .obj with render quality?
Thank you! :)
keith mcgregor
Re: .Obj File Export with Render Quality?
on Apr 2, 2011 at 8:17:14 am
Nah, you are only exporting the mesh and texture info. You have to set the lighting according to the scene its placed in. Only if you send the whole project directory to another workstation with the same program and open the scene there will it open with the right render settimgs.
-Beef
Reality? What did you make it?
