adding a roof to my house?
COW Forums : Autodesk Maya
Aja Shapiro
on Mar 8, 2011 at 11:00:39 pm
I'm a little frusted on adding a roof to my house using the Insert Edge Loop, can anone show me a step by step process on how to use it correctly? or if you know any other tips for this?
Matt Nielsen
Re: adding a roof to my house?
on Mar 23, 2011 at 2:33:11 am
There are a few different ways, if your roof is a flat surface simply extrude these faces up. Select corresponding edges then select Edit Mesh > Merge to Center. This will merges the opposite edges or vertices creating a single edge.
You could use the Insert Edge Loop tool and place the edge loop running through the centre of your building and pull this newly created edge up.
Just play around with some of the tools and you are bound to come up with something
