Shader Question...
COW Forums : Autodesk Maya
Mike Moss
Shader Question...
on Feb 4, 2011 at 4:45:28 am
I'm trying to achieve a shader or effect that looks like the following...
The black and white effect with the slight glow on the edges...
Anyone know a way to accomplish this?
I will be rending it out from Maya and using AE to composite it together.
Stuart Christensen
Re: Shader Question...
on Feb 7, 2011 at 4:19:43 am
Hey Mike, there's a ramp shader preset that may work for this, just create a simple lambert shader and then create a ramp shader, attach the ramp shader to the color channel of the lambert, then in the presets option in the tab, select (assign)the pre-made ramp called "ramp shade electron" to the lambert. This shader gives the white glow to the edges and it's a simple black and white adjustable ramp. There ya go! Stu
Mike Moss
on Feb 7, 2011 at 4:05:50 pm
Hey,
thanks for the response,
I found that preset you were talking about, I have not yet gotten it to look correct, but i figure with some more playing around with the ramps i could get it right.
Thanks for the tip!
By the way i posted another thread...maybe you know some helpful hints for that one also...It has to do with the same video...
