Hide selection doesn't work with animation
COW Forums : Autodesk Maya
Oskar Westerberg
on Jan 28, 2011 at 10:29:29 am
I select the object and click hide selection, and it works. Put when I hit play on the animation it re-appears. Why? This hasn't happend to me before. The problem is that I'm using som geometry as a container for some fluids and I want to render the container seperatly.
Michael Frank
Re: Hide selection doesn't work with animation
on Jan 29, 2011 at 4:56:43 am
Its likely that you have keyframes on "Visibility" parameter. If you hit the S key to set keyframes it will keyframe visibility. Hiding/showing selection basically turns that on/off.
You might also want to look into using render layers to set this process up.
Mike Frank
Cave House Studios
Oskar Westerberg
on Feb 4, 2011 at 2:35:03 pm
Thanks a bunch Mike, that explains it all. Darn keyframes, can't be trusted.
