Making an object appear along an axis MAYA
COW Forums : Autodesk Maya
Mario Epsley
on Jan 12, 2011 at 4:29:23 pm
Quite a difficult thing to describe.
I've modeled a chair for some one and i want to show the sizes and dimension of it in an interestng way. I thought it would be cool to have the object start as a plane (the side profile almost like the letter h), then i want this plane to extrude to the other side revealing the chair in its entirety. How would someone go about doing this? A simple scale out wont do, as it doesn't give the impression of the chair being revealed.
I tried putting the chair in a spherical environment with a green 'surface shader'. I then made another plane much bigger than the chair (i assigned the same green shader) and keyed the plane moving from one side of the object to the other. Because of the nature of surface shaders this has given me the impression i want. However it's rubbish because you don't see any shadows and the reflections are the same.
If anyone knows the correct way to achieve this it would greatly be appreciated.
© 2018 All Rights Reserved
