ideal render settings for pal dvd
COW Forums : Autodesk Maya
Dave Pritchard
on Dec 8, 2010 at 11:36:10 am
Hi guys,
Hope you can help with this, I want to render a scene out in Maya and burn it to a DVD using IDVD.
Can you tell me what the ideal settings are for...
Frame rate for a PAL DVD
resolution for a 4:3 pal image (768 X 576 or 720 X 576)
pixel aspect ratio
also, in after effects or final cut should the footage be interlaced before being burned to DVD in IDVD.
Thanks for your help.
DP
