Problem solving many dynamic objects in a pile?
COW Forums : Autodesk Maya
Rohini Dugal
on Dec 3, 2010 at 7:22:37 pm
We are having problems with 400 low poly boxes (50 faces each) as rigid bodies falling onto a floor object (passive rigid body) to pile up on top of each other.
After about 100 objects fall into the pile and become about five objects deep, the boxes start to get pushed through the floor by the force of the additional objects which fall on top.
We have tried increasing the divisions in the floor as well as placing several floors stacked close to each other but these have not helped.
Is there a setting which allows more passive rigid bodies to fall on top of each other.
Thanks.
Michael Frank
Re: Problem solving many dynamic objects in a pile?
on Dec 4, 2010 at 7:30:23 pm
Hmmm, thats a lot of objects. Have you tried setting Active/Passive Key? Maybe if you gave them enough playtime to hit the ground then set Passive, they would pile up instead of continuing to solve and bounce around off each other.
Mike Frank
Cave House Studios
