Maya Object grouping/moving problems
COW Forums : Autodesk Maya
Roman Gabriel
on Nov 25, 2010 at 1:24:14 pm
Hi, i managed to go so far without these answers but i came to an end.
I designed 2 robot arms, however, i have problems.
here are links to the first robot arm. i also included the outliner.
the problem is that when i try to move the skin, the joints/ik handles won't move along with the object.
also i have this problem with the other robot arm. Besides that it bent my polygons because of the joints, the base semi-spheres won't move as fast as the main object even though they're grouped. I also centered all the pivot points in one point so they will all pivot along the same axis, and still nothing. please tell me the problem
Here are the robot arms, and the problem. thank you
© 2018 All Rights Reserved
