Problem Vector Rendering on a Mac
COW Forums : Autodesk Maya
William Gadea
on Nov 10, 2010 at 9:48:27 pm
Hi, I'm running Maya 2011 on an Intel PowerMac with OSX 10.6.
It took me a while to realize that the Vector Renderer will only work in 32-bit mode. Fine, I've got it to load up now and can see it working in the render window.
Now my problem is that I can't batch render with it.
If I click on Batch Render options box it says "Warning: Renderer "MayaVector" does not provide batch render options."
If I just click on Batch Render it says: "Result: Rendering with Maya Vector... " and then about 3 seconds later "Rendering Completed" but nothing has actually been rendered.
Has anyone had this problem? Any ideas for what I might try?
Animation for Businesses
Michiel Duvekot
Re: Problem Vector Rendering on a Mac
on Nov 10, 2010 at 10:23:29 pm
Upgrade to SP1, it works there.
William Gadea
on Nov 10, 2010 at 10:42:23 pm
Great, thanks. I assume that might fix some other weird things that are going on too.
