Batch Render Problem, I need YOU !
COW Forums : Autodesk Maya
Stefan Meiller
on Nov 2, 2010 at 8:31:37 pm
Hello, i am using maya 2010 64bit, Windows7. 2GBRam
I have a problem with the batch render tool in Maya. If I want to render a scene,
- first: i get the message: Rendering with Maya...
- second: after around 6 seconds, i get the Windows7 Warning like: Maya Batch application file do not any longer.
In the task Manager i can find the mayabatch.exe for these 6 seconds.
Two weeks ago, everything is working fine. During the last days, I have tried something with new videocodecs, and codec packages on Windows7.
- Could there be any relationship between Maya Rendering and the installed codec stuff?
- How can I check this.
- Can I see which codecs Maya uses?!?!?
- What could be the reason for these errors.
Sorry for any kind of mistakes. I am from Germany, I hope you will get my problem.
Following you can find a Rendering Message File from Maya.
10/11/2010
Starting "C:\Program Files\Autodesk\Maya2010\bin\mayabatch.exe"
mental ray for Maya 2010
mental ray: version 3.7.53.5, Jun 17 2009, revision 88216
Prep offline copy....
Error: '-clearHistory' flag is not supported in batch mode.
arXaosSource command complete with 0 failed files.Prep offline copy....
arXaosSource command complete with 1 failed files.Prep offline copy....
arXaosSource command complete with 1 failed files.File read in 0 seconds.
Result: E:/MUDDERL_50_Geburtstag/FILM/EgyptStewie_01/1110_EgyptStewie_02Polishing_01b__3380.mb
Total Elapsed Time Since Start Of Maya (hh:mm:ss): 00:00:16
Resource Usage At Start Of Rendering
52616 Page faults
192.551 Mb Max resident size
191.938 Mb Peak total size(Estimated)
34.184 Mb Peak arena size
192.551 Mb Current
7.795 Mb Arrays
2.297 Mb Data Blocks
0.125 Mb Keys
22.344 Mb MEL
0.499 Mb Transforms
1.000 Mb NURBS AG
0.002 Mb arguments
0.125 Mb NURBS Surface Shapes
Rendering using 8 threads.
Automatic near/far clipping values: 0.1, 135.473.
Starting Rendering E:/MUDDERL_50_Geburtstag/FILM/EgyptStewie_01/EgyptStewie_0001.tga.
Constructing shading groups
Generating shadow map for pointLightShape2, with clipping values: 0.01 77.3471
Generating shadow map for pointLightShape2, with clipping values: 0.01 17.6897
Generating shadow map for pointLightShape2, with clipping values: 0.01 120.28
Generating shadow map for pointLightShape2, with clipping values: 0.01 67.0815
Generating shadow map for pointLightShape2, with clipping values: 0.01 53.3597
Generating shadow map for pointLightShape2, with clipping values: 0.01 80.1489
Rendering current frame.
Frame triangle count: 35370
Resource Usage At End Of Frame
15966 Page faults
231.621 Mb Max resident size
237.938 Mb Peak total size(Estimated)
66.026 Mb Peak arena size
232.984 Mb Current
7.795 Mb Arrays
24.500 Mb Render Cache
0.125 Mb Keys
22.344 Mb MEL
0.034 Mb Render Geometry Arena
0.499 Mb Transforms
1.000 Mb NURBS AG
2.218 Mb File Texture Mipmaps
0.002 Mb arguments
Postprocessing rendering result.
Time For Tessellation (hh:mm:ss): 00:00:00
Time For Shadow Map (hh:mm:ss): 00:00:00
Time For Post Process (hh:mm:ss): 00:00:00
Time For Frame Render (hh:mm:ss): 00:00:01
Finished Rendering E:/MUDDERL_50_Geburtstag/FILM/EgyptStewie_01/EgyptStewie_0001.tga.
usw...
Starting Rendering E:/MUDDERL_50_Geburtstag/FILM/EgyptStewie_01/EgyptStewie_0067.tga.
Generating shadow map for pointLightShape2, with clipping values: 0.01 53.36
Frame triangle count: 35358
8805 Page faults
237.156 Mb Peak total size(Estimated)
60.902 Mb Peak arena size
237.156 Mb Current
7.795 Mb Arrays
0.125 Mb Keys
22.344 Mb MEL
0.499 Mb Transforms
1.000 Mb NURBS AG
0.002 Mb arguments
Finished Rendering E:/MUDDERL_50_Geburtstag/FILM/EgyptStewie_01/EgyptStewie_0067.tga.
Resource Usage At End Of Rendering
425 Page faults
220.934 Mb Current
7.795 Mb Arrays
0.125 Mb Keys
22.344 Mb MEL
10.500 Mb Render Cache
0.499 Mb Transforms
1.000 Mb NURBS AG
0.002 Mb arguments
Total Time For Render (hh:mm:ss): 00:01:09
Total Elapsed Time For Maya (hh:mm:ss): 00:01:26
Scene E:/MUDDERL_50_Geburtstag/FILM/EgyptStewie_01/1110_EgyptStewie_02Polishing_01b__3380.mb completed.
11/2/2010
11/2/2010
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
11/2/2010
11/2/2010
11/2/2010
arXaosSource command complete with 1 failed files.File read in 1 seconds.
Result: E:/ANIMATION_MENTOR/CLASS_04/AM_Videos_Class_04/Videos_Week_05/Render_test/scenes/0211_Phonecall_Polishing_01g__2068.mb
// Maya exited with status -529697949
11/2/2010
Result: E:/ANIMATION_MENTOR/CLASS_04/AM_Videos_Class_04/Videos_Week_05/Render_test/scenes/1910_Phonecall_Polishing_02a__7800.ma
// Maya exited with status -1073741819
11/2/2010
11/2/2010
// Maya exited with status 3
11/2/2010
11/2/2010
Result: E:/ANIMATION_MENTOR/CLASS_04/AM_Videos_Class_04/Videos_Week_06/scenes/0211_Phonecall_Polishing_01g__5020.ma
Fatal Error. Attempting to save in SetUp_Ted_01:stewie_rs_L_hand_expr
Michael Frank
Re: Batch Render Problem, I need YOU !
on Nov 2, 2010 at 11:55:28 pm
What is your output file format? Are you rendering to a video format like .avi or .mov? If you're not, there should be no reason that the video codecs would matter.
The -clearhistory errors seem a little bit abnormal to me. I haven't seen a reason to for clear history during rendering, but I could be wrong. Or that might not be the cause of it.
Do you know how to start a batch render from the command line? That might give you some more insight.
Mike Frank
Cave House Studios
Stefan Meiller
on Nov 3, 2010 at 6:01:01 am
i am rendering an image-sequence, so it might ot be affected by codecs...
i have read another post that it could cause by hyper threading?! because i am getting the maya output code 1073741819.
- i this possible?
- how can i see\check if hyper threading ist enable or disable?
- how must it turned off
thanks a lot, Stefan
Stefan Meiller
on Nov 3, 2010 at 6:12:37 am
I have tried to render an image sequenc, so this should not be affected by codecs...
Whats about Hyper Threading?
I have read a post that the maya code 1073741819 will be caused if Hyper Threading is enable.
- is this right?
- how can check this
- how can i switch Hyper Threading on or off?
Thanks Stefan
Bill Beaumont
on Nov 4, 2010 at 1:44:10 pm
I just had the same problem. turning Hyper threading off solved it.
You can turn it off by going into your BIOS settings on your computer. As soon as you switch the computer on you should get a screen telling you what to press to go into the BIOS menus.
On my Dell it was F2. Sometimes it can be pretty fast so start pressing F2 (or whatever it is on yours) as soon as you switch on.
When you get inot the BIOS menus, look through till you find Hyper threading. Turn it off. Save and Exit and you compuer will restart.
Try rendering now.
For me I then got another error message, but simply tried to render again imediately after and it worked fine.
Good luck!
Stefan Meiller
on Nov 4, 2010 at 7:01:42 pm
now it is working again, sorry, i do not know why.
I have two .mb files. The first can be rendered. The second replys still the error. It could have to do with special light setting in the animation. I am trying to make a handy flash light... (hope you understand me :- )
So far, thanks a lot for your help.
