Simulating a Dandelion Clock in Maya
COW Forums : Autodesk Maya
Samuel Blain
on Oct 29, 2010 at 5:28:58 pm
Hey everyone,
I'm trying some test sequences for a university project and am running into problems trying to recreate a Dandelion clock dynamic simulation in maya, atm focussing on the seeds being blown off by wind.
My original idea was to create the seed head as a passive rigid body then attach each seed to it as a active rigid body connected by elastic particles that would snap whenever the seed was under enough force. After setting up some basic geometry with fields i got a basic animation where all the seeds just blew off however i was wanting to use the elastics to give the effect that some seeds hold onto the seedhead for longer, rather then all seeds just blowing off instantly. Once giving up in maya and taking it into RealFlow it became apparent this wouldn't work.
If anyone knows any other method to get around this problem that would be awesome :D. i had the idea that maybe i could use some kind of fiction between the seeds and seed head to keep some on longer then others.
cheers :D sam
© 2018 All Rights Reserved
