Changing an obects visibility over time
COW Forums : Autodesk Maya
David Lee
on Oct 24, 2010 at 7:47:29 pm
Hello all,
I had a quick look in the forums for an answer but could not see any.
I am rendering a short animation where i want an object to be totally invisible at frame 1 and over a period of time say 200 frames, appear totally visible. The object appears out of thin air.
I hear about visibility tracks but all I get is either on or off (1 or 0) visibility but I want a gradual appearance.
Is this possible?
Thank you
Stuart Christensen
Re: Changing an obects visibility over time
on Oct 25, 2010 at 1:38:11 am
Hello David, if the object is the same color, you can keyframe the opacity of the shader. Check out my tutorial on You-Tube here;
This is a simple way to achieve transparent to opaque effects.
Hope that helps. STU
I know alot....but not as much as the other guy.
craig whit
on Oct 25, 2010 at 5:34:53 am
Can this be done in comp rather than the render?
Craig Whitaker
MFA Candidate
New York University
http://www.craigwhitaker.net
David Lee
on Oct 25, 2010 at 8:34:53 am
What do you mean Comp Chris? Computer?
Michael Frank
on Oct 25, 2010 at 4:09:31 pm
By comp he means can you do the visibility animation in compositing?
If all you need is for the character/object to fade in.. Render that object as a separate layer and keyframe opacity in After FX or your preferred compositor.
Mike Frank
Cave House Studios
David Lee
on Oct 25, 2010 at 8:34:11 am
Stuart,
Thank you so much that worked great.
I was trying all sorts of things and I thought that it would be like MAX's visibility track where you can assign a bezier fade out but this works for me thanks.
ps I tried it with a phong material and that worked too but its a bit complicated with a mentalray material and I haven't had any luck with that yet.
Thanks again
Dave
