Selecting vertices
COW Forums : Autodesk Maya
Emily Scollon
Selecting vertices
on Sep 28, 2010 at 5:41:38 pm
I'm new... and simply trying to select vertices, but when i do its selecting everything behind the object... aka other nurbs/shapes etc not on the object itself. Sure its simple...
Emily Scollon
Re: Selecting vertices
on Sep 28, 2010 at 7:26:09 pm
figured it out, its on the top of the screen you have "hierarchy" "all objects" and "component" mode, and you can click each, if you are in component mode it only allows you to select vertices on the selected object! :-)
