Curves not rendering smooth
COW Forums : Autodesk Maya
Stanley Gucwa-Bucasas
on Sep 27, 2010 at 8:18:18 pm
I am importing paths from illustrator to create a logo in Maya. Basically the shape is a Rounded rectangle. I duplicated and lofted the rectangle, and lofted them together.
The curves on the new lofted surface are smooth in the preview windows but when I render, it still comes out blocky.
The render setting are set to highest quality, I feel like I've pressed every other button to get it to work but no luck haha.
Tylor Larson
Re: Curves not rendering smooth
on Oct 20, 2010 at 4:48:30 pm
what kind of surface? poly or nurbs. i would guess, you need to adjust your tessellation settings if it is a nurb... personally, if you are going to do a logo i would suggest using bevel plus.
© 2018 All Rights Reserved
