Cluster aligned vertically instead of horizantly
COW Forums : Autodesk Maya
Asad Kazmi
on Sep 22, 2010 at 1:11:45 pm
hi,
i am rigging a model from a tutorial , when in a tutorial he deformed cluster they are aligned vertically in a line at every joint but when i am deforming them they are aligned horizontally in a line on top of each other instead of line like they have same pivot points , more over i selected the neck joint to create cluster and it placed it in middle of the spine instead of placing the cluster at the selected joint. i aligned the pivot but it does not makes any difference as well.
what i am doing wrong.?
any help will be appreciated.:)
Asad Kazmi
