nonlinear bend wont keyframe
COW Forums : Autodesk Maya
chris hargreaves
on Sep 2, 2010 at 11:34:36 am
Hi, trying to animate a single non liniar transformer bend attatched to an object but when i try and animate it the keyframe wont work properly,
for eg
i set the frame, the object is hilighted and in position hit keyframe (s) then move to selected frame, move the bend and keyframe again but it just keeps it in that position when i move to the origional frame.
please help asap as im at work and need to do this as soon as i can
thanks for your help
Kristi Sendlewski
Re: nonlinear bend wont keyframe
on Sep 3, 2010 at 5:41:55 pm
Hi Chris,
I had a problem like this too. The way I fixed it was I had to right click in the curvature box and say set key frame. It worked from then on with Auto key but I think if you want more control and are animating manually you might have to right click each time. Personally I just stuck with auto key and went from there!
© 2018 All Rights Reserved
